The Nokia E71 is a smartphone from the Eseries range with a QWERTY keyboard targeting business users worldwide. It was released in 2008.
6вопросов Показать все
How to get the cover off Nokia E71 to remove dust
Is there a good way to pry off the front cover so that you can dust off the screen underneath. Worried about cracking some connectors if I go about it the wrong way. Pretty tight fit and not sure if it is designed to be taken off.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I hate to just Google it for you, but I Google'd it for you. Here it is :
Nokia E71
Regards,
Frank
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Thanks! (Feel really stupid.....)
Good photo guide. Note: you will need one of those special octagonal screwdrivers (the tiny ones) to undo the screws in the second picture
из
"special octagonal screwdrivers" - it's called Torx - the size in that case was T4 ;-)
из
Look for this procedure:
Disassembling Nokia E71 Complete disassembly
Оценка 1
Добавьте свой ответ
Tze Wen Leow будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 11,931
