Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Two SSD Drive Raid 0
Just wondering if it is possible to install 2 SSD into Mac Mini Late 2012 model and do a RAID 0 ?
I bought 2 kits from ebay and none of them able to detect the "Upper" SSD.
Is there any differences among those cables ?
Это хороший вопрос?
Счет -1
2 Комментариев
There does appear to be an issue with a double SSD setup refer to this question: SSD will not show up after installing
из
As I expressed to Radjin someone with the setup needs to speak to Apple as it does appear the ML installer has an issue and I suspect the EFI firmware may as well here.
из
Добавить комментарий
1 ответ
Выбранное решение
Apple does have a problem with both the Mountain Lion installer as well as within the systems BIOS (EFI).
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Is this an answer or a comment?
из
Answer per Apple - See other Answer for the background SSD will not show up after installing
из
After reading through all the info on the other question, I take it that the answer is "No" right now.
из
Yes, it's no for now.
из
Добавьте свой ответ
Agustinus Harjono буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 2,416
