Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
186вопросов Показать все
The video port has a loose connection.
I have an original Playstation 2 and it is definitely showing its age. The port that the original AV cables connect to in the back of the console have become worn out with use over time. When I attempt to play my games the screen flickers on the t.v. or I lose video altogether. Audio is still present, regardless. Is there way to order the part to replace this port and solder to the board? Or, does anyone have a nifty hardware hack to wire new leads directly to an AV cable? I am assuming all I would need for the second choice is the pin out diagram for the PS2. I have several AV cables just laying about that I could use.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
Did you try a different Audio/video cable?
Sometimes the wear and tear is on the plug of the AV cable and not the AV port of the PS2.
Also try inspecting the AV cable's plug that connects to the PS2. Make sure that none of the pins or the metal shroud is bent or broken.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
I do not have another cable to try out, but I was able to check the pins on the cable and, guessing that they may be loose from the years of use, I pried each of the pins towards the center of the plug. This seemed to help a little bit. The screen does not flicker as much as it used to but still does go out from time to time.
из
Yes But it did not work
из
The metal part to av cord came off will it still work???
Оценка 0
Добавьте свой ответ
Kelly Louwers будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 16
За последние 30 дней: 78
За всё время: 17,597
