Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
Logic board LCD connector damaged
I am about to buy an iPhone 5 apparentyly it's previous owner while trying to chnge he's LCD screen damaged the lcd connetor on the logic board, apparentyl it's bent. Has anyone been able to fix this, any tips...
Это хороший вопрос?
Оценка 0
1 Комментарий
Apparently i can buy some components here on etrade and replace the connectors with new ones, but i guess i will have to solder them to the logic board, and that i hope is not to hard lol
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Replacing any connector on the board is a straightforward board-level repair, but not really a DIY project. Sending the board out to have the connector replaced is a great way to save the phone and costs less than a screen.
Most shops that offer board-level connector replacements on iPhones will already have all the connectors in stock. It can be tough to find certain connectors--especially on late model phones. These almost always have to come from China and even then the stock can be limited for certain connectors.
You *can* sometimes get away with just reshaping the connector--many times it is just a single pin that is bent down. With great care and magnification, you may be able to use fine tweezers to straighten that pin. Best would be to replace it, but reshaping may help you in your diagnostics to see if this is the only defect in the phone.
jessa
Был ли этот ответ полезен?
Оценка 6
1 Комментарий:
How do you find companies that will perform board level repairs that cost less than a screen? My local repair shop quoted $144.00 for a connector replacement on a 5s.
из
Yes, the connectors are available. Most of them are not an easy find, but they are out there. The soldering is a different matter. Unless you have the right tools and great skills soldering very small contacts to a surfaces mounted devices, I'd be a bit more cautious....good luck.
Оценка 1
8 Комментариев:
Ok so i shall buy the connectors and find someone with the skills to mount them on the logic board, that's the best thing i can do...
из
Yes, that would be the way I'd approach this.
из
could u do that with an iphone 5s?
из
Can it be done? Yes, if you can find the part and know how to microsolder.
из
Anyone know if the motherboard that connects to the touch function of the lcd screen if if that gets replace will it affect the data on the phone will the phone be factory reset ?? All functions are working just only the screen I can't scroll or touch I want to know if I get that replace will
My data be affected ?
из
Показать 3 больше комментариев
Does someone know if iphone 5G and iphone 5C has the same LCD Fpc connector?
Оценка 0
1 Комментарий:
Yes, they are the same.
из
Добавьте свой ответ
achapgase будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 16,846
