Repair guides and support for water softening systems.
How to repair a water softener?
Is there a repair manual for water softener? Our's is a PRO Series E E-70.
It just cycles won't turn on, release the water.
Это хороший вопрос?
Счет 3
3 Комментариев:
Crystal, that is a ProFlow SA-PRO-E 70? what cycles and what won't turn on?
из
The tank comes on and makes a lot of noise as if the water was cycling through ; however, it never stops and water never releases.
из
Water pressure drops from time to time in the kitchen faucet or bathroom shower
из
Добавить комментарий
2 Ответов
this might help
http://docshare01.docshare.tips/files/12...
Был ли этот ответ полезен?
Счет 0
The incorrect regeneration cycle of your water softener might be caused by a number of factors. This includes an inadequate supply of electricity, a power outage that resulted in an incorrect setting of the clock, and a broken timer. Replace the damaged components to make the cycle functional once more.
Счет 0
Добавьте свой ответ
Crystal буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 29
За всё время: 1,452
