How to repair a water softener?
Is there a repair manual for water softener? Our's is a PRO Series E E-70.
It just cycles won't turn on, release the water.
Это хороший вопрос?
Это хороший вопрос?
this might help
Был ли этот ответ полезен?
The incorrect regeneration cycle of your water softener might be caused by a number of factors. This includes an inadequate supply of electricity, a power outage that resulted in an incorrect setting of the clock, and a broken timer. Replace the damaged components to make the cycle functional once more.
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 24
За всё время: 1,106
Crystal, that is a ProFlow SA-PRO-E 70? what cycles and what won't turn on?
из oldturkey03
The tank comes on and makes a lot of noise as if the water was cycling through ; however, it never stops and water never releases.
из Crystal
Water pressure drops from time to time in the kitchen faucet or bathroom shower
из osiomesiete
