Water from cold water dispenser is not cold.
Это хороший вопрос?
Это хороший вопрос?
Asked and answered:
Был ли этот ответ полезен?
If the compressor is running and does not shut off, then it is low on Freon
I can not get any water to come out the cold water push bitton. When I push the button on the right for cold water no water comes out at all.
Water is not cold from Water Dispenser. I can not hear the compressor running.
Is there a way I can check to see if the compressor is burnt-out.
Handy Man
За последние 24часов: 2
За последние 7 дней: 11
За последние 30 дней: 35
За всё время: 14,164
4 Комментариев
water from cold water dispenser is not cold
из David Galindo
what l can do f dispenser is not cold?
из jerry tantuan
Please let me know where the fuse is???
jpagliughi@gmail.com
из John Pagliughi
Oddly, the water is acceptably cold during the summer months when the temp in the kitchen is about 75. In late fall & winter temp is 70 due to heat running. I find no external thermostat / cold control as in a standard reefer. What gives?
из Barry Thompson
