The HP Pavilion dv9000 series was introduced in 2006.
Вопросов 20 Показать все
While turning on my computer it freezes at a black screen?
after i power it on all of the buttons turn blue like always and then about 2 seconds later it freezes at a black blank lit up screen. please help all family pictures are saved on there.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (3)
Выбранное решение
This is usually a bad GPU with the 2007 DV series and this is usually the common failure point that tells all. However, it can also be a bad LCD but this is rare. To verify, plug it into a monitor and see if it locks up or does the same thing — if it does the GPU is bad, if not bad screen.
  • When the GPU’s fail, you tend to have POST problems. Try the RAM if you want, but if it persists the GPU has failed.
  • The GPU failure is usually indicated by a solid black screen. This may be a backlight or LCD problem, but it’s very unlikely. If the external is bad, the GPU is absolutely going to be dead.
  • These systems also have a tendency to lock up when the high level driver kicks in. However, garbage on the LCD is also common for partial failures. Both of these indicate a bad GPU and that any further attempts are probably a waste of time.
When this happens, the laptop is toast. Get your data off and scrap it or give it to someone to strip for parts. The problem is caused by poor cooling and the problem still occurs, even with the upgraded heatsink which requires the revised motherboard to install since the GPU placement changed as a part of the “fix”. HP only acknowledged fault when they were sued and only covered one of the 2 bad machines. Their “fix” was a hack to shut the lawyers up and it did absolutely nothing to stop new failures outside of absolve them of new liability.
  • In some cases, it may be possible to pull the data in safe mode but only if the GPU is partially dead. You will need to press F8 to do this. If your GPU is totally dead, you will need to remove the hard drive(s).
  • Log into the hidden admin account or your account on XP. This is disabled in Vista by default, so you will need to enable it or use your account.
  • Save the data to a USB flash drive or DVD. I use DVD’s for clients because it’s cheap and I don’t need to worry about liability; once I’ve given them the data I’m free and clear.
If the GPU is so bad the machine is beyond Safe Mode recovery, the hard drive(s) need to be removed. You can save these as your backup, but I’d really recommend copying the data off to another drive as these drives can fail. This is what I did on a DV9000 (factory dual drive configuration), but the procedure isn’t any different on single drive machines.
  • You'll see two doors on the bottom of the laptop that hold hard drives. These are marked with 3 platters and are marked 1 or 2 on dual drive systems. On single drive models, look for the 3 platters only. Remove the 2 screws that secure the cover.
  • Remove the screws that hold the drive in. Put these with the caddy or screw them into the chassis.
  • Remove the SATA adapter(s) and stick this in the machine.
  • Remove the drives from the caddy you want to get the data from if needed.
    • Plug the drive into another PC and extract your data. Check Users for Vista and Documents and Settings in XP for common data; some is stored in more obscure locations in programs like Works.
    • Copy the data from the drives to another machine.
Был ли этот ответ полезен?
Оценка 2
I had two of these and both times the gpu went on it, they run too hot so the gpu either fries or needs reballing. It's possible sometimes to rescue them by reflowing the gpu with a heat gun, this melts the solder again and fixes any dry joints.
To get your info off the laptop you can try plugging it into a tv or monitor with a VGA / monitor cable, as a lot of the time you can still get a picture on the monitor when you can't on the laptop screen, I know this was the case with both of mine that died.
Оценка 0
ive had the same issue for me it was the lcd inverter went out so the black screen was actually the screen going dim i could barely notice the windows startup if i put the brightness to max.
Оценка 0
Добавьте свой ответ
Natalie будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 4,046
