Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218вопросов Показать все
I mistook the home button ribbon cable connector
I have broken off the square 5 wire connector next to the home button ribbon cable, and all the soldered leads are no longer attached. How to repair?
I have attached two pictures from the guide. I mistook the connector as the picture was a little too small to see, only after "prying up the flap" did I discover I pried up the soldered connector.
Is this repairable or have I junked my new iPad 4th ten pride and joy?
Here are pictures where the connector is shown as right next to the cable connector…
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
The connector can be replaced but the leads may need to be re-routed. It is a difficult repair, you could ruin it further if not done carefully
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I just found a repair service who will solder a new connector to my logic board for $50 plus shipping. Will advise once I have it back in house.
из
Добавьте свой ответ
Al Taylor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 426
