Display not working after replacement
I just replaced the display. I plugged it in and it worked. Removed it, installed the digitizer and replugged the display and now the display won't come on
Это хороший вопрос?
Это хороший вопрос?
Try a reset. Hold down the power button and the home button simultaneously until you see the apple logo. If this doesn't work, you likely blew a fuse. You can google the fuse locations and replace it or bridge it with a bit of solder. Good luck!
Был ли этот ответ полезен?
Hi,
Wait until the battery is discharged. This can happen if you remove the display before power off the device.
Regards.
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 165
