Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
How to unfreeze screen
Screen froze while charging stating that there is not enough storage I cant turn it off and it will not allow me to choose any apps on screen or even slide to unlock or slide to turn off its just stuck please help this phone is my husband and he Is blind and he uses siri for everything,!!!!????????
Это хороший вопрос?
Счет 5
2 Комментариев
For iPhone user, this method will help you a lot.
How to Unfreeze an iPhone
из
wow good job
из
Добавить комментарий
2 Ответов
Выбранное решение
Hold down the home button and the power button until the unit shuts down. Then release them both. If the phone doesn't reboot on its own, you may have to press the power button to turn it back on. Make sure that you do not hold the home and power button while the phone restarts because you may accidentally put the unit into DFU mode which would result in losing everything on it - unless you have a program like RecBoot or Tiny Umbrella to kick it out of DFU with!
Good luck!
If you found this to be helpful, please up-vote or Accept Answer.
Был ли этот ответ полезен?
Счет 6
9 Комментариев:
OMG! Thank you so much. It worked. It had been frozen for three long days. I had almost given up. Thank you for your posted answer :)
из
Glad to help Debra!
из
Thank you! Your a life saver.
из
Thank you, that worked!!!
из
I really want to say thank you. Your advice worked. Thank you very much. You have been extremely helpful during a hectic time of my life.
из
Показать ещё 4 комментариев
i really need your help.. My iphone 4s Freeze and i can't Turn off it because the Notification Center Hang What i will do to fix it?
Счет 0
2 Комментариев:
I would unscrew the back and take off the wire connecting to the battery then plugging it back it and try turning your phone back on. I think this video is helpful https://www.youtube.com/watch?v=aSUirUBm...
из
Hi @advadvsdv! I feel terrible that I let your comment hang in limbo so long! Did you get this resolved?
из
Добавьте свой ответ
joann буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 34
За всё время: 5,430
