Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
Вопрос закрыт
Need help on troubleshooting
I was wondering if anyone knows if it is possible to test a logic board for function without installing it back into the frame? I have a board pulled and am working on, and I was wondering what I would need to make it function without having to reinstall it over and over. The Lcd/Digi, Battery, dock and power button flex. Does it need the frame for the grounding?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Выбранное решение
I believe it does. you should put it back in the frame for testing.
Был ли этот ответ полезен?
Оценка 1
nope. You can totally test it outside of the frame. Solder a lead to the bat + and - pins and attach to alligator clips to a DC power supply. You can use powerflex to power on, then disconnect and take readings on both sides of the board. I'm doing it right now :)
jessa
Оценка 0
2 Комментариев:
What should the DC supply be rated to? I assume a 9V will have different results than a car battery.
из
I mean a benchtop variable DC power supply specifically used for troubleshooting electronics. Pick one up for $100. You can use it for all sorts of things--charging dead batteries, pushing current into phones with a short to allow the heat buildup to show you where the short is, and doing what you're doing here--testing a phone without using a battery.
You would give the phone exactly 3.8 V---9V or 12V would kill it.
из
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 115
