My galaxy 3 tablet keeps getting hot what do I do?
Its getting hot, I mean very hot after only a few minutes of use. And its only in one corner. Its the left upper corner.
Это хороший вопрос?
Это хороший вопрос?
Upper Left corner is where the battery starts its charge... or discharge... I'm guessing that theres a short in the battery. I'd send it in to get looked at
Был ли этот ответ полезен?
But its not getting hot while its charging. It could just be sitting there and I pick it up and its reallly hott. Cause I thought about it being something with the battery so I checked while it was charging and it was cool as a cucumber. Thats why im so confused as to whats going on.
Well, then your battery doesn't idle when you lock it, it's still discharging when you're not using it. Are you experiencing less battery life? If so it's most definitely the battery... Get it replaced!
As far as I can tell the battery is fine. Ill watch it closer the next few days though. Thank you.
No problemo!
actually samsung galaxy tab gets hot really quick due to usage of RAM and cpu so its normal . it is not mad for heavy use just to store pics listen to music and to play a small game and when u do something which takes alot of RAM and cpu the tabs left side will get ,infact the cpu is on the left.
Thank you!! Ive noticed its only when im using netflix or playing a game so that makes sense!! Big weight off my shoulders!! Cuz I cant afford to fix it if something goes wrong!! Thank you!!
That make since if I leave an app running then pick up my tab its hot as on the left corner
I think when your continually using the tablet for gaming or installing stuff it does get hot just let it cool down and try not to use it to much
u must had kept it on a tv or laptop or a computer thats why or else water must have entered in it or battery problem
In my opinion put yor tablet on charging in that room which is cool don't keep it near the room which is very close to kitchen as it could be heated by steam from kitchen!
Actually its cuz of the way u use it. If u leave it in charge and use it, it will get hot. U have to be careful. Use it for about an hour and let it cool. If it still gets really hot, don't use it and power it off
I play words and scrabble and my tab 3 gets real hot in 2 hours or so. I turn it off for a few minutes and it cools down to normal
Chances are the battery is getting warm. Try replacing it.
За последние 24часов: 4
За последние 7 дней: 17
За последние 30 дней: 42
За всё время: 35,561
11 Комментариев
i had a rca tablet and the battery on it quit working and it wont even charge anymore
из Michael Wilson
My rablet gets hot regardless of amount of usage, or type of usage. I've even unplugged the chargeing cord, and the tablet still continues to heat up. I turn the hot area in another direction and the opposite area then gets hot as well. I'm exteremly baffled.
из Suzanne Johnson
Suzanne. So, if your tablet gets hot when it's charging, that's normal. When it's charging, the battery is getting power but also releasing it at the same time, so the battery will heat up because theres twice as much going on in there. If it gets hot whether it's charging or not, that's most likely the CPU. If it is, then when you use an app that uses a lot of recources (Like a 3D Game) it will get hotter, but it shouldn't overheat.
из Mount MC
It keeps getting hot my tablet
из Virgil Steele
My tablet gets hot all on the left side top and bottom whats wrong
из Anamarie Rodriguez
Показать 6 больше комментариев
