How to replace navigator flex cable Galaxy S4?
The menu and return buttons don't work.
Это хороший вопрос?
Это хороший вопрос?
It's a difficult task. The navigator flex cable hides under the display and exists between the screen and frame.
You want to replace the navigator flex cable, i suppose you have to separate the display from the frame. You need a lot heat, and when you put the frame back, you will need a kind of special glue.
It's complicate, good luck to you!
Был ли этот ответ полезен?
you do have to separate the glass, but what I did was just opened the bottom part just enough to take the damaged flex cable and put the new one back in. It was very difficult, it'll help to have some tweezers to take it out and maneuver the new one in there. Patience is the key my friend.
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 14
За всё время: 1,193
