Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
Вопрос закрыт
water damaged, after cleening, it wont turn on at all
I have dropped my iphone 5 in water I took out straight away and left in a bag of uncooked rice for a day and then cleaned it with isopropyl alcohol. I reassembled everything but now it wont turn on at all, it wont even be detected by iTunes. please help
Это хороший вопрос?
Оценка 5
1 Комментарий
I just pulled a dumb !@# move at the water park. When putting my iPhone 5 back in my pocket after taking pictures, my power port cover on my LifeProof case must have caught on my pocket, and popped open. I TOTALLY flooded it.
I have had zero luck in repairing it, so if you get any more feedback zarealy , please post. I have a tendency to lean towards Richard's answer,,and feel a little low,as I had just paid the phone off with AT&T. :-(
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
The battery is most likely shorted and you will need a new 1
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
I have tried another battery I didn't work
из
Sounds like the motherboard maybe fryed you will need a professional to take a look and see can it be brought back to life..
из
Apple's iPhone is pretty much known for their sensitivity to water especially 5 most likely both your motherboard and battery are fried completely. I would suggest replacing the motherboard and the battery the rest should be okay but to be sure check all the leads of anything that isn't new. Usually after the motherboard has water it won't be able to be brought back to life.
Оценка 0
1 Комментарий:
That really isn't true. If you skip the rice, don't try to turn it on, and get your phone to a professional ASAP then most phones can totally be saved.
из
"Cleaning" an iphone 5 without desoldering the EMI shields is pretty much the same as doing nothing (in my experience.)
Jessa
Оценка 0
1 Комментарий:
i have the say problem and i have remove the emi shields
dosn t turn on
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 10,919
