The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Burned camera lens .
Hello
I am a medical student and i used my mobile camera to take pictures from a microscope but i think the extreme light from the microscope burnt the lenses because when I try to take pictures in low-light occasions the picture I get is red and pink.Can I fix it ?
Это хороший вопрос?
Счет 1
1 Комментарий
Did this happen recently or has it always acted this way in low light conditions?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
This is not an uncommon issue it would seem, several HTC 1 users have run into the same problems, HTC has officially acknowledged the problem and believe that it may be a firmware issue with the phone. This was acknowledged last year, if you can, I would see if there is a firmware update as HTC believes it is a software issue. If you cannot wait and you are still under warranty you should be able to ask for a replacement if it is in fact the issue.
Also I would try to lower the ISO levels. HTC is advising users to reduce the ISO levels to lessen the impact of the flaw, or return their handset and receive a replacement.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Thank you for your response
из
Of course, I hope that helped
из
Добавьте свой ответ
Demetris Fkiaras буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 19
За всё время: 3,208
