Left Trigger Not Working, and Start Button
I opened my controller recently because of the said defects. The Left Trigger is not jammed or dirty or anything it just doesn't work. Same goes for the start button. Im thinking to replace the whole part of of the Left trigger but I don't have spare parts.
Any suggestion?
Thanks in Advance
Это хороший вопрос?
Счет -1
2 Комментариев
ive done that and still nothin all my controller wants to do is aim on its own
из
@ronald, what exactly do you mean by "wants to do is aim on its own"? It is moving on its own at all times? Sounds like a bad analog stick.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
I would suggest reading this comment from a previous question, it could be the contact points.
My left analog stick doesnt work when you press it down.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
ok, going to clean and re-solder the contact points. Is the Sensor/Switch of the LT Button same as the Analogs?
из
There is no LT button, there is only a potentiometer. It is not part of the analog module but they share a common space causing the LT trigger bracket assembly to overlap the analog contact points unlike the RT analog stick which don't overlap making that side the easy one to fix .
из
Добавьте свой ответ
mojr31 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 7,727
