Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
How to replace the digitizer?
I read the guide and watched a few youtube videos, but when I tried to replace a cracked iPod nano 7g digitizer I couldn't get the LCD out. I ended up breaking the thin metal frame around it and scratching it, as well as bending it. I successfully removed the digitizer. How do you get the entire display assembly out? Also, will an iOpener help me remove the small back piece (above bluetooth antenna), as I had trouble with this as well? Thank you.
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
The iOpener should help. Make sure that the spudger is under the entire display assembly to prevent bending the metal midframe.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
JT7 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 468
