Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154вопросов Показать все
Speaker Connector pulled away from logic board: all 6 pins are broken
Hello and Thanks in Advance this is my first time posting a question but I use your site religiously so Imma give it a try. I was given an I pad 3 wifi to replace a broken screen and when I started tearing it down I realized it also needed a new LCD and the battery wouldn't hold charge so I assumed it needed a new on. This is the 1st battery replacement I have attempted on an ipad of any kind and I think I made a big screw up. As I was unconnecting the wifi cable, speakers and the dock connectors I was alittle unsure as of how to pop the speaker one up and when I finally pulled the connector came off of the logic board leaving 6 little prongs there. At this point I did not think I had messed up I thought I would just pop the connector back down onto the board and that would be it. Boy was I wrong, let me add that this repair went super smooth besides this, when I tried to line the speaker connector up with the prongs I couldnt get it and eventually I pushed one down. I took my tweezers to raise it back up and it just broke away from the board. This ended up happening with all 6 of them Now I have to idea what to do, how to fix it, or if I have just ruined the speakers on this ipad. Any help would be greatly appreciated. I can even take a picture of it if you need one. :)
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
This is repairable as long as solder pads are intact. Without a microscope and micro soldering experience, you might want to send it out for replacement of the audio fpc connector socket. If you can't find anyone local, feel free to ask me for a mail-in repair quote via clicking my profile and sending an email.
A picture would also help here.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Libby Perry будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 964
