A push button control blender with stainless steel blades manufactured in 2011 by Oster.
Why is my blender not turning on?
I have turned on my blender and the blades do not turn when I press ON or when I select a speed.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
It is possible that your blender is not plugged in. Check to make sure that your blender is properly plugged into a operating power outlet and then try to turn your blender on again. If your blender still will not turn on, your power cord may have faulty connections. Look at your power cord and see if it is broken or torn. If it is broken or torn you will need to replace the power cord with a new one. If neither of these solutions work to get your blender to turn on, you may have to replace the circuit board.
Click here for further help.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Victoria Mark буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 6,844
