The EOS 6D was released in 2012 as Canon’s first consumer-level, full-frame DSLR. It comes pre-equipped with a 2.75”x2” LCD viewing screen, a GPS antenna and wifi connectivity.
Why does my battery die so quickly?
My battery on my Canon Eos 6D has been dying very quickly after I messed with some settings. Can anyone help? Do I need to repair anything on my camera or buy a new battery?
Это хороший вопрос?
Счет 3
1 Комментарий
turn off GPS
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
One reason for a short battery-life is that the camera's GPS system is activated. The GPS system draws a lot of power from the battery and as a result has a large impact on battery life. Refer to our troubleshooting guide to learn how to deactivate your camera's GPS.
Был ли этот ответ полезен?
Счет 4
You most likely have either your GPS or Wifi on. turn those devices off will save you a ton of energy.
Счет 1
If the GPS is on it will stil be on even if the camera is turned off and it will drain the batteri.
Счет 0
Another thing that could be killing your battery is if you turned off the automatic shut off option. You can have it shut off at 1 minute or 30 minutes. What that does is essentially put your camera in sleep mode. Once you press your shutter half way down, it will come back on. I accidentally turned that off one day and didn't realize it. My batteries would die like crazy and then I realized the camera was actually staying on all day. instead of going to sleep. Hope that helped!
Счет 0
Turn Off WiFi when you don’t use it
Счет 0
Добавьте свой ответ
Geremy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 19
За всё время: 2,084
