Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782вопросов Показать все
Вопрос закрыт
I need Help ASAP ..,
Hello,
I have my MacBook Pro shutting down randomly by itself, and when I went to the Apple store, they did replace the battery to fix this issue. But the issue still presents. So, I need your help ASAP.
TaHANK YOU.
Это хороший вопрос?
Оценка 0
1 Комментарий:
Need more info. Is is unplugged when this happens? What the problem history on the machine? What system are you running? When did this start and had you done anything to it prior to this starting?
из
Добавить комментарий
1 ответ
Have you been placing your phone on the computer? I have heard that magnets in the phone can trigger the shutdown. On my 17in 2011 macbook pro I set my phone on the bottom right corner and the computer goes to sleep, this is because there are magnets in the monitor and the computer detects the monitor's magnets and goes to sleep. This is how the computer detects the lid being closed. My friend once did this by accident somewhere else on his computer and it shut down. Make sure you are keeping magnets away from your computer.
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 52
