The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730вопросов Показать все
Power Button Works, but, Will not sleep/wake display
I did a screen replacement and a flex cable replacement on an iPad 2, CDMA.
In short, the power button will turn on and off the iPad, however, pressing the power button will not put the display to sleep or wake it.
I'm assuming that the square circuitry on the flex cable, between the volume buttons and the board connector controls this and could be bad?
Any suggestions?
Это хороший вопрос?
Оценка 2
4 Комментариев
Hey Lurch, long time no see, you've been missed.
из
thanks mayer. glad to be back.
из
John, good to see you back.
из
Thanks oldturkey03.
Note to all the folks: if mayer or oldturkey03 answers a question with more than two paragraphs, yup, ya better bookmark it! ;)
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Most likely case is still bad/damaged flex. Post back if two new cables have failed.
jessa
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Well this is the second flex. The first had a bad volume down, but, I really can't recall if the sleep/wake worked. This second flex, all is well, just wondering if the square circuitry on the flex cable controls the sleep/wake feature.
из
Yup, only thing I can do. It's not unusual at least once a year or so to get a bad batch of flex cables, etc. Fast production = higher chances of faulty parts.
из
Can't figure out how to cut iPad off. I assumed I could hold button down and it would cut off. Any advise?
Оценка 0
Добавьте свой ответ
Country Computer Service будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 920
