Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Dropped & screen is cracked
I dropped my Ipad Mini. Not very smart when it comes to these devices. What do I need to buy to fix the screen?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
Tom,
For the iPad mini the replacement glass screen, aka digitizer, comes in two flavors.
1.) A plug and play option---which is described as "iPad mini digitizer with touchscreen ic and presoldered home flex"
2.) A 'glass only option' --which requires you to desolder and transfer the original touchscreen ic and home flex from your cracked digtizer.
I'll also add that a couple of idiots on eBay actually sell glass only which is a useless piece of glass that is not even a digitizer for the same price as a digitizer.
iPad mini screen replacement is hated by many repair shops--those suckers can give you a lot of problems. Make sure to read up on this repair before you begin to try--there can be a lot of pitfalls---especially cracking the LCD on disassembly, blowing the backlight fuse, removing pins from the digitizer connector on the motherboard, and digitizer ghosting.
Nevertheless, this repair is do-able as a DIY project---on this one it will definitely pay off to do a little more research than usual.
Был ли этот ответ полезен?
Счет 1
Наиболее полезный ответ
Hi there is it just cracked does the picture at all look damaged if not then you just need to buy the glass digitizer
Счет 1
1 Комментарий:
The picture looks ok. I think the screen is just cracked. So all I need to purchase is the glass digitizer? Is that a glass type front that slips on?
из
Добавьте свой ответ
Tom буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 265
