The glass is just a square order of double Dimond clear float glass, A glass shop cut height and width for me. (cost $30)
laid it on the iMac and traced the corners with a very fine felt pen.
Then bought a glass cutter and cut the corners just a bit larger than they should be.
Used a belt sander with an extremely fine grit belt, and had had someone spay water at the contact points between the glass and the belt sander as I slowly wore it down to the felt pen marks.
cleaned the glass well with non ammonia glass cleaner.
Placed it back on the iMac and marked the black put areas. Used a quality frogger masking tape to cover the centre screen viewing area that was not to be painted, used a small round sticker to cover the spot for the top camera lens. Lightly just touched the areas to be painted with 240 grit sandpaper. cleaned glass again with soft no lint rag and no glass cleaner. Used ceramic black spray paint from 2 feet away, making 3 light coats, placed in a pre heated oven at 250 f, then turned it off so it would heat fast but cool slow. This bakes on the ceramic paint
Cut the glass off the screen with floss is the best way, twist a few stands together, but it will take a lot, do not use heat at all.
Do not use UV fluid, it is a horrific toxic substance that your bring into your home.
I am using just clear non acid based high quality silicone (fish tank silicone) to glue the glass back to the screen. Just a thin even coat that I dropped 1 corner on first and slow laid the rest down. moved the glass in different directions to work out the extra chalking. Final positioning, wiped off the extra oozed out chalking with vinegar then let it dry over night. Then reinstalled the screen, Note that it takes 2 weeks for the silicone smell to go away and would not leave it in my house for the first few days anyways, a garage is best, cold will not affect the bond or the cure. I want to try wild colours instead of black, but it has to be ceramic paint, for all other types will loose bond with the glass after a short while, really is a low cost fix.
Был ли этот ответ полезен?
Проголосовали
Отменить
Счет
2
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
5 Комментариев
Hi Mr. now much have you pay for LCD from china ? i want me too one but it's wery very expensiv.
Thanks
из Smadoiu Florin
I am working on the unglue in it. I am 20% off i have been applying heat and metal cord to separate the surfaces, pretty messy and I will try the no heat option and the dental floss. I have two breaks screens, one the Lcd and the other one the glass, trying to make one of it, I will add some update soon.
Wish myself luck
из sergiocb
let me know result.
из JamesKim
I successfully took apart and cleaned off glue from lcd. It's easier than iPhone as the lcd is not as delicate. I hope I can find the glass portion only and it's impossible. this is the closest website I could find that lists a possible direct contact to a manufacturer. I have cleaned the glue off the lcd using goo be gone.
из Jane Schwerdt
Take the computer to any glass shop and let them cut you 2mm clear glass, wont be perfect (no black frame anymore). I tried to paint a black frame but paint wont stick to the inside since the double sided tape is peeling the paint out of the glass. Searched a lot for that part and i couldn't find it. best option is to cut out glass, as I said. If you feel artistic paint it, but from the outside...
из Tarek Hesham
