Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
Water Damage; Home button not working?
Hi All,
I dropped my iPhone in the toilet (like many have LOL). I did everything I see on the net ie, placed it in rice, placed it in an airing cupboard. After a week, the only things that weren't working were the home button and speakers. I opened it up and cleaned it with electrical cleaner— then back in rice and the airing cupboard for another 3 days. Everything is working apart from home button. I sent it off explaining what had happened, and they replaced the home button—which didn't resolve the issue. They said it has extensive water damage to the circuit board!!
My question is, if this is true, how is it that everything else working just fine? Could it be something else? I have read here that it could be the docking port. It just seems such a shame that my phone works perfect apart from the above, and I'm being told it is beyond repair.
Many thanks for any advice/help,
Bev
Just a quick update... I got my iPhone back from the repair shop, and it is in a continuous recovery mode loop—and when I try to restore, I get error 29!!!
I've read about this, and I know I did not upgrade to 3.13. The only thing I did before sending it off was back up all my data on iTunes.
I can't help thinking that they are using the water damage as an excuse because they have caused it to go in this loop.......I really don't know what to do or where I stand in this matter.
Это хороший вопрос?
Счет 2
5 Комментариев
== It's working fine now == but Apple repair saw the liquid damage indicators and that voids the warranty.
Yes it could be the docking port - or something else. What's curious is that they sent it back "repaired" but not working?
N.
из
I dropped mine at the beach and I'm having the same problem. What did you do to fix it. Even though they said rice wouldn't work I tried it anyways and it didn't help.
из
i dropped mine down the toilet, could only get siri and then the home button stopped working did this and it works just like new. remember settings, general, assisted touch-turn it on voila
из
me too my Iphone got wet so i put it direct into the sunlight with in 30 mins . Facing the charging socket up and God ! Its all working :D i just want to share it :)
из
If you are in emergency and you don’t get the help soon, that means nothing. Here, we are available for you all the time and it take less time to reach you. http://www.asapwaterdamagerestoration.co...
из
Добавить комментарий
8 Ответов
Наиболее полезный ответ
Just add a virtual home button. That works as good as a regular home button.
Go to: Setting>General>Accessibility>Assistive touch (put it on mode)... you are all set. Use the virtual home button with all the features.
Был ли этот ответ полезен?
Счет 6
6 Комментариев:
thanks jazk313 - i used to use the home button to close out of all my apps by double clicking it. any other way to do this without the home button now that it's shot?
из
Oh this was a life saver!!! My phone ALSO got wet and also works everywhere else except the home button. The assistive touch button allows me to close my app and return to the home page. Thank you!
из
i need to get to my home screen but it is stuck on the app. any suggestions on how to get there?
из
Thanks so much for this. I am now able to use the home button features through the virtual home button
из
Great tip, phone is now able to be used. Thanks
из
Показать ещё 1 комментарий
the power button is most likely shorted - it can be replaced or cleaned (i prefer cleaning, 6$ are 6$ ;-))
most problems after fluid damages are shorted parts - putting a device in a bowl of rice won't help. cleaning the parts with isopropyl alcohol or electronic cleaners is way more effective.
Счет 4
Quick way of identifying problem.
Open and short home button pin pads on dock. If this works then you know it's a home button flex cable or home button pin problem.
If it doesn't work the it's the dock or dock connector, or the dock socket.
Счет 1
I have this problem too. To get out of the recovery loop just charge it for about 20 minutes and unplug it. You'll still get the display telling you to plug it in, but all you have to do is hold the power button to turn it off and then turn it back on. This should start your phone again like normal, but every time it dies you'll have to let it charge for a while turn it off and on again and it should be fine. It's a pain but it works for me. As for the home button, there only 6$ on ebay so I'm going to order one and replace it myself. It's worth a try and It's a ^@@% of a lot better than paying the greedy bastards at apple 200$ for a cheap fix. Hope this helps. Good luck
Счет 0
ive got the same problem.... i put mine in a puddle and my home button wont work yet voice control comes up when i start. my water indicator things are still white so its showing no sign of contact. im taking it back to telstra to get fixed.. would they fix it seeing the stickers are saying its not water damaged and there still white..
Счет 0
1 Комментарий:
I got exactly the same problem as Zoeeee. Its pretty annoying. Also, my light does not work. So if it's dark i have to put my iphone near some light to see something. This happend after I felt asleep with my iphone next to me , think i just rolled over it a couple of times. BUMMER.
из
Washing up dishes and listening to a pod cast, whoops, there it went - splash. Got it out before it hot the bottom of the bowl, but it was completely underwater. Read everything here, all seemed to work okay just minutes later - that's when I noticed the home button was not working. Not having a #00 phillips I tried hitting the circumference of the home button pretty hard with compressed air - function was restored and worked for a few hours.
Heading to Lowes to get the screwdriver to take it apart and hot the inside, but for those with similar issues give compressed air a try.
Счет 0
1 Комментарий:
Compressed air will blow wet into where it's dry... not a good idea. Follow some of these suggestions for drying electronic devices..
из
Error 29 is usually a bad battery which should always be replaced when it gets wet. Lithium ion does not like water. Ifixit sells the correct part # 616-0435
Счет 0
@sao
If you double tap the virtual home button, it will act the same way as the actual home button, enabling one to close the apps.
Счет 0
Добавьте свой ответ
bev буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 26
За всё время: 90,924
