The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
How do I get the cameras to work again?
I have had this phone for 2 months and both cameras stopped working. I try opening the app and it instantly dies and goes back to the home screen. Also on snapchat the screen shows up black and will not show anything that the lens would be showing.
Это хороший вопрос?
Счет 117
50 Комментариев
If there's someone who can help me, my HTC can not take pictures.
из
I have exactly the same problem on my camera and other apps such as instagram,snapchat,whatsapp every app that uses the camera does not let me take a picture, Someone please help it's stressing me out now I've had this problem for almost a month
из
I have a solution that worked for me! Go into Settings - Power - Scroll down to the bottom and uncheck Fast boot - Restart Phone.
из
My sefile is not run. And than dou effect is not work. Now i cant
из
unchecking fast boot worked for me! yay thanks!
из
Показать ещё 45 комментариев
Добавить комментарий
20 Ответов
Выбранное решение
Hi Buddy
My HTC Camera is not working at all, when i tried to open the camera it open and it shows black screen and then after sometime it comes to home scree.
Can you tell me how to rectify this issue.
Rgds
Sameer
Был ли этот ответ полезен?
Счет 58
27 Комментариев:
Privacy guard... Yeah.. Problem fixed. Thanks :)
из
I didn't find Privacy guard. Where did you find it? The main camera is not working.
из
Its worked!! Thank guys.
из
Bro, I had also this problem. Now it solved
http://www.gogorapid.com/fix-samsung-gal...
из
Показать ещё 22 комментариев
try doing a hard restart . please update the phone software ,
please close all other background app and rsetart the system .
for more follow Guide - steps fix to Phone Camera in phone and try to see if this helps to fix the camera
Счет 12
1 Комментарий:
My duo camera stopped working but front camera is still working well please help me .
из
Hey Jacob, here are some things things that I recommend you try:
-Try to 'clear data' under 'camera' in app manager.
-If you're using Lastpass try and do a factory rest.
- If you are using the Lastpass option "Enable fill into apps" and turn it on in accessibility settings then the camera issue might be there. Maybe if you turn it off camera works fine.
-Let me know what happens.
-Hope this helped
Счет 6
1 Комментарий:
Please I need help my HTC m8 windows can't open camera
из
SUCCESS!!! first of all thank you for all the suggested solutions. What worked for me? Someone suggested that we should find the apps that use the camera and disable them and VIOLA!!!! that worked for me.
go to settings
then apps
click on each app and scroll to the bottom of each app (each one has to be done individually)
under permissions if the camera is listed you scroll back up and disable the app.
i did not disable messenger though
I VE GOT MY CAMERA BACK!
THANK AGAIN!!!!! HOORAY!
Счет 4
Guys, this is the solution. It worked in my phone.
go to settings then to applications. See which application is using the camera then force stop or disable it. For my case, I forced stop the application called privacy guard and my camera worked perfectly henceforth.
Счет 3
2 Комментариев:
how do you determine with app is running your camera
из
из
I turned off phone took battery out blew off any dust put battery back and cover it started to work again
Счет 3
3 Комментариев:
you can't take the back off a htc m8 because you have to take the screen out to get to the back of them
из
Not true mine slips off the back it's a bit hard but does open
из
Not sure about m8 my phone is about 3 years old
из
Счет 3
2 Комментариев:
no this does not work. stop making false solutions
из
This did work for others, that was rude. Not everyones issue has the same cause.
из
When faced with this problem,
1. Review the last apps you downloaded (Settings>Apps>new downloads)
2. Review to see if it uses the camera for any reason
3. If yes, press the Force stop Bottom
4. If 3 above didn't work, you will have to uninstall the app (s)
I did the above and it turned out an app (Swifty) which I recently downloaded, was the cause of the problem.
Счет 3
2 Комментариев:
My HTC M8 is brand new from box but camera not working. I have tried to follow all the instructions here but to no avail. What should I do to this brand new hone?
Phillip
из
If u installed Security 360 just remove this app and restart your mobile phone.
из
Счет 3
I found an answer but I can't explain it just yet. I have a program that allows my home screen to rotate. Whenever I enable that program the camera does not work in portrait mode. Just get a black screen. However the camera does work in landscape mode. If I disable that rotate program the camera works in both portrait and landscape mode. Not sure what caused this to happen just yet. I thought I remember it working just fine at first. My guess is something got borked and it will take some cache clearing or something to resolve fully. As for now my work around is just to disable the screen rotation when I want to use the camera.
Счет 3
What i did is i just stopped the camera ihad!!and i don't know if this is a option for you-but i just downloaded another camera and it's working nicely! Hopefully so can you!!!!----sue
Счет 3
1 Комментарий:
I downloaded a new camera but its
still not working
из
I just opened the back on my phone and fiddled and cleaned it a bit where the connection is, when I rebooted it worked again...
Счет 3
I had the same issue even after factory reset. Then I upgraded my software to marshmallow....
The camera is now properly working
Счет 3
UPDATE I got my camera back for a while, it broke again. I'm tired of trying to fix this. I have had no camera for a while now
Счет 2
I don't have no front camera every time I go to the camera and pick the little square box I don't see the selfie sign.
Счет 0
1 Комментарий:
Same issue. Can anyone assist please?
из
My camera won't work the message" camera has unexpectedly stopped " shows up did all the above and a factory reset and still doesn't work
Счет 0
1 Комментарий:
I suffering from same issue, if you have any solution please share
из
I had a lot of problems with my htc...
I'm disappointed....
And also my camera doesn't work
Счет 0
2 Комментариев:
My HTC Desire 530 front facing camera has also stopped working...did all the above...no help...very frustrating ..can someone please help all of us ? HTC peeps?
из
سلام مهسا ، مشکلت رو تو تلگرام بگو راهنماییت کنم
@HaCKeR071
из
Hi
Duo camera is blocked problem after replace camera , plz help me ,
Счет 0
1 Комментарий:
HTC makes great phones with too many issues which gives customers tons of migraine. In the long run it's not worth buying.
из
Has anyone contacted HTC and has their phone fixed? I've had my HTC One M9 for 3 days and this has just happened to me.
Счет 0
My camera it's not working
Счет 0
2 Комментариев:
My HTC One M8 main camera has stopped working after change of the accumulator battery. Just a black screen. I will try two solutions provided here - turning off "Autorotate" and switching off all the apps that use camera. Will tell you the result soon...
из
My HTC One m8 selfie camera is not working camera app quits to menu when I go to selfie mode and on other apps like snapchat selfie can shows black image
из
Добавьте свой ответ
Jacob FUEHRER буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 17
За последние 30 дней: 112
За всё время: 189,349
