The Samsung Galaxy Grand is an Android smartphone manufactured by Samsung Electronics and released in January 2013. It is also known as the Samsung Galaxy Z I9082Z in India. Models: GT-I9082, GT-I9082Z, GT-I9082L.
50вопросов Показать все
battery drains fast even after replacement with new battery
my battery drains quickly even after replacement with new one
Это хороший вопрос?
Оценка 11
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Make restore factory setting
It's working 100%
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
it is working great
из
I did factory reset...
Still having the battery issue. When it gets to 70% after full charge. It goes off. Bought another battery, observing same issue.
из
This is a common problem in most Galaxy phones,
#Make sure the replacement battery is original and not a knock-off
  1. Try not to run many apps at the same time
  2. The phone (or the battery) could not be faulty, the Galaxy Grand is supposed to operate for 3-4 hours with a Li-Ion 2100 mAh battery
  3. Consider buying an external power bank (battery) This power bank should last with you for a good 15-20 hours before needing to be recharged.
Оценка 1
this appear when the phone have 3 problem 1- maybe the pf ic is damage.2- you charging is not work good 3- you have a lose connection in charging part
Оценка 0
Try using ShutApp its a task killing app the "Force stops" apps running even without your notice. Most of the running apps drain your battery really quick as soon as you turn on mobile data or WiFi so I recommend you use or download ShutApp.
Оценка 0
1 Комментарий:
I dont know how it works
из
Добавьте свой ответ
inderjit singh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 20
За последние 30 дней: 101
За всё время: 11,451
