Miniature one watt version of the classic Marshall half stack. With a tone knob and overdrive channel, it offers portability without sacrificing playability.
7вопросов Показать все
Micro Amp Battery power not working.
My MS-2R micro amp by Marshall has never failed me in the past but I recently noticed that when I try to use battery power it doesn't work. The wall input works and sounds fine but the battery power doesn't work. I have replaced and used at least 3 different batteries but still no solution.
please help, have a nice day
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Had same problem
I Took the thing apart and there was nothing wrong, I took the wires off the battery contacts and put them directly onto the battery and it worked. So I discovered the problem was the battery wasn't wedged up against the the contacts hard enough. So I cut a piece of card and folded it in half and wedged the battery in there. Switched it on and it started first time, never had a problem since
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Ahhh thank you!! This worked for me - I also had looked inside and all wires seemed fine - did as you suggested and bingo!
из
Добавьте свой ответ
Jellyfish будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 19
За последние 30 дней: 38
За всё время: 3,036
