Repair guides and support for Canon's EOS Rebel XSi, also known as the EOS 450D. This is a DSLR camera released in 2008.
22вопросов Показать все
Is it possible to change the flash if it stops working?
Is it possible to change the flash if it stops working or if it will no longer will pop up?
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Lauren, first I would check this page. follow the troubleshooting for the flash issues.
Был ли этот ответ полезен?
Оценка 1
There is a tiny micro switch in the Hot Shoe (flash attachment on the top). I have seen where it will get stuck in the down position. Therefore the camera thinks it has an external flash on top. Use a straight pin or needle to pull the switch back up.
Оценка 0
Make sure you have a good strong battery. I have had to clean the grooves under and around the flash with a cutip and toothpick using minimal alcohol
Оценка 0
Добавьте свой ответ
Lauren будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 712
