Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782вопросов Показать все
What is this part?
I can't figure out what this part is. I am replacing the upper case on a macbook pro. Look at this guide:
MacBook Pro 13" Unibody Early 2011 Upper Case Replacement
In step 36, you can see it. It is under the right speaker and it looks like a flat plate with an antenna wire attached to it. My new case didn't include this part and it doesn't seem to come off of the case.
Can anyone tell me what this is?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
That is a ground for the antenna. It should come attached to the top case but can be removed by taking out the small screw that is at the top of it, but it also may be attached with adhesive. (I am a former apple tech and never actually removed it due to it always shipping attached to the new top case.)
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks plam.
из
Добавьте свой ответ
stdonato будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 51
