How do you remove LCD from case
It looks like around the hinge the LCD casing is broken. I would like to replace the casing without replacing the whole LCD.
How do I open the casing so I can see which side is broken.
I can be reached at
Thank you for your help
Erik
Это хороший вопрос?
Счет -1
1 Комментарий
machead3
Great Link
It's exactly what I needed
Thank you
из
Добавить комментарий
2 Ответов
Выбранное решение
Once you get the top off the bottom
It should be very evident which one is broken see: http://www.PowerBookmedic.com/mac-repair... Display removal followed by hinge replacement.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Был ли этот ответ полезен?
Счет 2
It's a difficult repair to replace the LCD casing on the PB Titanium since it is glued to the LCD and hard to glue it back in place. You could find a whole replacement display assy for cheap if you search the web (ebay, craigslist, etc).
Счет 1
Добавьте свой ответ
Erik буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 1,928
