I got my phone wet, HELP!
I accidentally left my phone in my pocket when I went to the beach. When I realized it, I took it apart and left it out to dry, but it still won't work. What should I do? Is it a lost cause??
Это хороший вопрос?
Это хороший вопрос?
Changes are that it's a lost cause by now, but you could try to dry everything out in a tub of rice. The rice absorbs any extra moisture that might be still in the phone. Make sure you don't have any sand stuck in it as well I guess. You can use canned air to blow that stuff out.
Был ли этот ответ полезен?
No. Just no.
Try to soak the logic board in at least 90 percent rubbing alcahol, i used it for a iphone 4s that went thru the washing machine and dryer but it needed a new lcd, although it connected to itunes. try a new battery also, that usually helps too.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 173
