A range of desktops aimed at the mainstream consumer market, spec-wise situated between the Inspiron and XPS lines released in 2009.
55вопросов Показать все
Random errors, but how are they connected?
I have multiple things that my Dell Studio 17 will do that all seem to happen at the same time, but don't seem to be related. Here is what happens:
  • Flash player stops working and crashes browser
  • Bluetooth devices will not connect
  • Skype crashes
  • iTunes will not open
I have no idea how any of these would be connected, but the all seem to happen at the same time. I am going to reinstall the OS soon, but I just would like to know for curiosity's sake.
Thanks for your help!
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Andrew I'm going to make a guess that you are probably using some form of Windows. The most likely common cause I can think of would be a shared dll that has become corrupted somehow. I believe your planned OS reinstall should clear your problem by replacing the dll. To be on the safe side I would install the programs one at a time and use them for a day or so before adding the next. That could help you find what is causing the dll problem. Hope this helps you. Ralph
Был ли этот ответ полезен?
Оценка 2
One easy attempt to repair it is by using system restore. look it up as it's different to access between operating systems. All you need to do is choose a restore point on which the computer was working fine; really easy. good luck!
Оценка 2
Добавьте свой ответ
Andrew Guenther будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 874
