Why is my trigger not firing?
My trigger is loose and will not fire when I squeeze it.
Это хороший вопрос?
Это хороший вопрос?
If your BB gun is not firing it can mean one or a combination of five things: 1) Too many BB's in the loaded in the gun 2) Safety still might be on (easy fix simply push the little black button above the trigger until you see a red line on the pushed out portion of the button, then safety is off) 3) The BB's you are using could be damaged or dirty thus causing blockage at the firing chamber 4) BB's are not aligned in firing mechanism 5) Broken Trigger Most of these things can fixed easily while others especially a broken firing trigger might take a little more work to deal with. Refer below to the troubleshooting and repair guide to help walk you through correcting this issue
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 25
За всё время: 14,686
