Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782вопросов Показать все
Вопрос закрыт
MacBook Pro (Not Charging) MagSafe Board + Battery Connector replaced
I have a Macbook Pro 13 early 2011 , suddenly sent me a message that my battery is not loaded , check my magsafe and LED indicator marked as green , a term for Macbook PRO downloaded and faded .
Then I thought it was my battery was failing and buy a new one, install it to load and my magsafe still indicating LED green , so I decided to try my charger in another Macbook pro thinking that there was a failure , but this charge the other battery Macbook pro without problems making the change to amber indicates charging .
After I put my new battery in another Macbook Pro where I tried my charger and it works flawlessly there .
Then as he was slow my Macbook pro install from scratch Yosemite thinking that perhaps it would recognize my new battery recognizes sends me having only 2 cycles without loading.
Then perform the SMC reset by pressing the Shift , CTRL, ALT keys AND ON FOR 5 SECONDS and nothing , change the card where the magsafe is connected to the motherboad and nothing, I do not know what to do, someone can help me .
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Try the replacing the battery indicator on side of machine by the hd if same issue then board issue
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 617
