Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782вопросов Показать все
Installed new broadcom card... now no bluetooth
So I just installed a new Airport/bluetooth card i(4.0 ie BCM94331PCIEBT4CAX) into my Early 2011 Macbook pro... when I turn my computer on... I was happy to see my Wifi Working but it says no bluetooth hardware detected.
Since there is WIFI doesn't that the card works?
Or is it a defective card?
Could I have not attached something properly?
Or is it a software issue???
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
David, I would dry a PRAM reset before declaring it defective. Sometimes this forces the machine to recognize new hardware. Also, what do you see under System Profiler under bluetooth? Anything there?
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
I'd also reset the SMC.
из
I just tried to no avail
It also shows nothing under system profile
Оценка 1
1 Комментарий:
double check if the bluethoot connector is well inserted in its socket.
из
Добавьте свой ответ
David Burkholder будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 309
