Why does the projection clock "on" button keep turning off?
Whenever I turn the projection clock button to the "on" position, it moves back to the "off" position and will not stay on.
Это хороший вопрос?
Это хороший вопрос?
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 411
2 Комментариев
After some research, I discovered that the unit needs to be reset.
Resetting process:
Remove batteries and disconnect adapter for 15 minutes.
Reinstall batteries and reconnect adapter.
Hold reset button for 5 seconds located in the battery compartment or on the back of the unit.
(A paper clip or pin will be needed to fit into the hole for the reset button.)
из Kathy Rowley
Projection Clock RM318PA Troubleshooting.
из Kathy Rowley
