The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56вопросов Показать все
Why wont my microphone pick up any sound?
I am getting told frequently from multiple callers that my voice is muffled or even non existent. I can not make any recordings on my device. I think there is an issue with my microphone.
Это хороший вопрос?
Оценка 3
1 Комментарий:
How do I check whether my microphone is muted
из
Добавить комментарий
2 Ответов
If you are experiencing issues with the phone's microphone, try using the solutions below to fix the problem.
A common issue for this might be that the Mute button is on. Check that the microphone is not muted.
Test the microphone by connecting a wired headphone that has a microphone. If the headphones work while connected, remove the headphones and continue onto troubleshooting the internal microphone.
Test the audio by going to a quiet area and restarting the phone. Once restarted, record a new voice note by going to Messages and attaching a a recording to the message. You may also try and do a Skype Test Call. Skype is available from the Windows Store to download free of charge.
Finally, the issue may be a simpler one. Check and see if the microphone's opening is blocked. If so, use a dry cleaning cloth to wipe out any dirt or blockage.
Again, if neither of the above works, you may simply need to replace the microphone.
Был ли этот ответ полезен?
Оценка 0
A solution could be a quick observation of the casing grill, dirt filter and microphone. In my case, I cleaned the dirt filter, casing grill and even wiped the microphone but it did not help. I realized that the dirt filter was misaligned with the casing grill and therefore sound was blocked by this. I used a heating gun to soften the dirt filter and removed it, re-aligned it with the grill casing and ultimately the microphone. This fixed the whole voice muffled on caller's end issue. (To breakdown this problem: Outer casing has to be clean. Dirt filter has a dedicated microphone hole that should be aligned to any hole on the outer casing. The microphone should fit on the dirt filter without any obstruction.) Hope this helps someone out.
Оценка 0
1 Комментарий:
I have a simaler problem but my mic picks up sound when recording videos but not when using it as a phone
из
Добавьте свой ответ
Zadan Ly будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 7,262
