2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265вопросов Показать все
MacBook stuck on grey screen with apple logo and spinning wheel
Macbook pro retina display stuck on grey screen with apple logo and spinning wheel i tried everything that i could find on the web even replaced my hard drive cable with new one my friend told me that he thinks it might be the hard drive but i also have windows 8 installed on my macbook and windows 8 is working fine but macintosh is not hopefully someone could tell me what could be wrong
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Help us help you. The more complete the description of your problem is (what Mac OS you're using, did you use bootcamp or some other emulator? Some history - when & why the behavior started) the more assistance we can provide, and, the sooner we can provide it.
When you say "tried everything" that means nothing to us. List the steps you have attempted, and their result.
Have you seen this article from Apple? If you are using Lion or later (OS ≥10.7 ) instead of a separate utitiles disk you would use Command-R. to access disk utilities.
If this answer is acceptable please remember to return and mark it accepted.
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
the mac os that im using os x maverick and i tried the disk utility i tried reparing it but it said everything is okay i also tried restarting the ram and also changed my ssd cable but nothing helped
из
also performed a safe boot and Reseted the NVRAM / PRAM and nothing happened
из
So how long have you left it spin? Sometimes it can take 10 minutes or more for a boot. The OS may be doing things in the background - especially if this was right after an upgrade to Mavericks. To reiterative: you are certian you have 1GB RAM, 9+GB HD space, and it's not an EFI update (dark bar) issue
из
Добавьте свой ответ
junior будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 555
