Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794вопросов Показать все
Error 4sns/1/40000001:VPOR-0.003. Water Damage, acting up?
I had water damage a few day ago, it was completly dead, the water got by the BIOS Chip, I clean it with alcohol and turns on now. Since that happened, the computer is doing werd things.
-When i connected to the MegSafe it turns on by itself (with battery connected and lid close only).
-When I run APPLE HARDWARE Diagnostic I get the error 4sns/1/40000001:VPOR-0.003
-When is off with battery connected and I touch by the mousepad it wil tunr on by itself.
Thank you in advance
Это хороший вопрос?
Оценка 1
2 Комментариев
Change your battery for a known good one and re-evlauate based on "(with battery connected and lid close only)."
из
Friend, I am with this same problem. You managed to solve?
из
Добавить комментарий
2 Ответов
Выбранное решение
Some sort of Voltage problem power bus ''(from your description you should have already surmised this)'' . Sorry I can't be more specific.
4sns is at the beginning of every sensor error the data at the end of the error code points to what hardware that is out of spec, and, numbers usually represent how far out of spec the hardware is.
Did you run the diagnostic with the magsafe connected or on battery only? Some power errors come up if the unit is not plugged into the mains during the test (or if in your case the main power supply is unstable).
If this answer is acceptable please remember to return and mark it accepted.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
It was connected to the Megsafe but the battery was disconnected from the board. Now, all those issues that I have only happen if the battery is connected. Could the battery be damage and causing these issues even when the water didn't reach it? Thank you
из
Yes it is possible
из
I have a similar problem but ca not find:
apple error 4sns/1/4000000:vpor-12.764
Оценка 0
Добавьте свой ответ
Carlos Solano будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,618
