How to repair this green screen? Please?
my screen on galaxy s3 turns green and sometimes wont light up just black screen. i hope theres a way i can fix this because the lcd is not totally broken.. Thank you in advance. :(
Это хороший вопрос?
Это хороший вопрос?
Hi JuanMiguel Gealogo,
My friend unfortunately I have bad news for you, while your display still works it is permanently damaged. There is no fixing this issue, there is only replacing the screen with a new one.
What has happened is the display has been damaged below the first layer of glass, you cannot see the damage because the front glass is covering it, by removing the front glass you will be able to see the damage.
It must be a minor crack in your LED, small enough to only distort the display and not make it go out completely.
But its only a mater of time before the device gets bumped to hard or dropped and it will finish the small crack and make the display stop working completely.
Its time for a new screen.
Hope this helps get you going in the right direction.
V/R
Josh.O
Был ли этот ответ полезен?
Please help me out. My phone got into water. its a samsung galaxy a5 I stuck it in a bag of dry rice for 24hours it came on and looked the same but after a while the colors of the letters and pictures starts turning green and then starts fading out like a washed picture
I have the same issue
How much would a screen replace cost? I dropped my phone and it's turning dark green and then black, it's the same issue i found out but i have damaged it even more or even less.
Please solve
My mobile is Samsung note 9 I am too much worried does tap the the screen work
Take glass of tap DA corner of ur LCD screen I jus did it nw and its back to normal no green Any try it c if it works mite b different but try it
Could you please explain what you mean a little better? I'm not sure what Take glass of tap DA means?
@Butterfly Monkey Mumma "Tap"means to hit it gently. "DA" is just a slang for the word "The".
this worked thanks so much
this works like magic THANK YOU
hello i hope you can help me my note 3 have also a green screen and make a no dislpay but and his back a normal and i used for that ..please help me what can i fixed this ..thank you my friend
Though the LCD isn't broken on your device, it looks like it is defective, if you have experience taking the S3 apart, and access to an additional S3, you could simply switch motherboards to test it. Honestly, it would be best for you if it is the screen, because the only other possibility is that your main logic board is having issues, which isn't good at all, in that case you would have to get a new phone all together.
My screen is always green no matter what i do. It started when i tried the negative colours option. I have Samsung galaxy S3 too...
i have a s8 and half of its screen goes green whenever i start it sometimes it flashing and sometime it isnt its just green. irlly need a solution
why ploblem this solution change display or
Hi my phone does thing except it is a samsung s5 i tried turning up the rightness and it worked for me but it still goes green for like 5 seconds when i turm on the home screen with my middle button and it takes about 10 seconds to actually turn on the home screen in the first place even with my brightness up.its worse when i put my brightness at the lowest option though... hope i helped... im no expert just putting that out there im only 14
Tbh with you all... i dont have a clue...
My stupid chuffing phone is dojng this too but i dont Have a chuffing clue how to fix the chuffing problem
What rubbis ideas are been posted.....ha ha
love and hope thats all you need (and a credit card)
Ok so I have a Samsung s8 the screen just went green I haven't banged it dropped bumped or knocked it jus went green you can still try and touch the screen like putting in the code and as much as i cant really see the numbers or letters i can see that its still working on the finger touch my friend saw a code on screen that said something about system after taking this to the shop they just want to replace the screen wot to do ??
I dont understand??
replace or remove charging port.
My screen also turns green and model of my mobile is samsung note 9 I am very much worried about it and it becomes green when I open any appp
My daughter's tablet was looking exactly like this and apparently she had turned on bedtime mode so turning that off fixed the problem.
I also have a the same problem with my S9 plus.. I haven't dropped my phone as well.. why my phone have a green screen?
За последние 24часов: 6
За последние 7 дней: 40
За последние 30 дней: 144
За всё время: 180,907
2 Комментариев
I sort of have this same kind of problem. Say for instance I'm watching youtube or Netflix then sometimes, and it always happens while streaming, my screen will freeze then turn green. I also have a problem where my phone will restart all by itself. I have a galaxy s3 version 4.4.2. I'd rather not have to get a new smartphone, since this is my first one ever and I don't have the money for a new one anyway, so I'd like it to last as long as possible.
из Casey Graham
Casey does your phone do this on a regular basis? Does the screen turn green under normal use like when making phone calls or texting ,playing, games or is it only when streaming . When the phone shuts down is the phone warm to the touch?
из Jimfixer
