no power no start
Hi I have a Honda accord 1997 automatic 4 cylinder. Last night I was driving it then I stopped the engine and wnt to start it again and now it won't start unless I jump start it. I just replaced the battery about a month ago and the alternator about 2 months ago so I doubt its either of those and I just replace the battery fuse today. Any suggestions? Im really puzzeled by this.
Это хороший вопрос?
Also, I forgot to mention that my car gets no power when I turn my key and the engine doesnt even crank. It doesn't even really make a sound
из jordan
So it will start but you have to jump start it?
из oldturkey03
Yes. Otherwise it won't start at all. However, I did have to try to start it a few times when I jump started it
из jordan
For now it sounds like you have a dead battery. See if you can use a battery charger to charge it, then you will have to check your charging circuit. Right now, unless you have a known good battery, any suggestion will only be a guess.
из oldturkey03
Alright thanks man. How would I check the charging circuit?
из jordan
Показать 1 больше комментариев
