Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577вопросов Показать все
Loudspeaker does not work after screen replacement
A customer came in with a Galaxy S5 that he had replaced the display assembly on himself. Overall, it actually looked like he did a fine job of it. However he said that after he changed the screen, the loudspeaker worked once, then when he turned the phone off and back on it stopped working and has refused to ever since. He still gets sound out of the headphone jack and over Bluetooth connection. He has tried everything (and I do mean everything, I asked) short of replacing the actual speaker unit with no luck. If a new loudspeaker does not solve this problem, what could be going on here?
Это хороший вопрос?
Оценка 3
Добавить комментарий
3 Ответов
Did you ever figure this out?
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Sadly no...I have not seen the customer again either.
из
i have a phone in with this issue
Оценка 0
I have a phone with this issue too replaced speaker and checked all pins and nothing
Оценка 0
Добавьте свой ответ
JonMark будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 1,495
