have software damage from a virus how do I fix it?
My phone was hacked and I cant get settings or other apps to work. How can I fix this?
Это хороший вопрос?
Это хороший вопрос?
Factory reset sounds like the solution your looking for.
Caution this will delete any data on your device
Hard Reset
Switch off your device.
Press and hold the following keys at the same time: Power/Lock Key + Volume Down Key.
Release the Power/Lock Key and Volume down Key when you see the Factory Hard Reset screen.
Press the Power/Lock Key to confirm (or press any other key to cancel). When you press the Power/Lock Key to confirm, the message "Are you sure you want to continue with erase?" is displayed.
Press the Power/Lock Key and your phone will be restored to the factory settings. To cancel, press the Volume Keys.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 362
