Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203вопросов Показать все
Вопрос закрыт
Display shut down when completely open, works if partially fold
Hi there,
I have a MacBook A1181 mid 2009, which has this problem: when I open the lid, it only works at the opening, but when I put it into the correct position, the display shuts down (the pc is still running). So I have to use the Mac with the lid partially close, it works only in this position.
I think it is a problem in display cable...
Any suggestions?
Do I have to change the inverter cable?
Это хороший вопрос?
Оценка 0
2 Комментариев
Following the guide, it was an easy peasy job.
40min of work, many bucks saved.
Thank you guys
из
Glad I could help. Remember to keep your data backed up!
из
Добавить комментарий
1 ответ
Выбранное решение
Your diagnostics skills are good. Here's how to do it: MacBook Core 2 Duo Inverter Cable Replacement
Был ли этот ответ полезен?
Оценка 2
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 80
