A portable e-book reader developed by Amazon. Repair is straightforward and requires only prying tools and screwdrivers.
Can the USB socket be replaced without replacing the motherboard?
Это хороший вопрос?
Счет 7
2 Комментариев
This is for the kindle paperwhite.
из
I can’t recharge the battery .The yellowflashes intermittentantly as I wobble the recharging cord seemingly there is a connection problem.
What do I have to do to restore the charging capacity.?
Have tried several recharger cords.
Your advice would be welcome.
Thankyou
Mairin Campbell
из
Добавить комментарий
1 ответ
Выбранное решение
The USB socket is soldered to the motherboard, so it can not be easily replaced without replacing the motherboard. In theory the socket could be replaced with some careful soldering work if you could get your hands on a replacement socket. For someone experienced with replacing small components on circuit boards I'm sure it would be possible, but if you are a beginner with this sort of thing you may do more damage to the circuit board by overheating it. Look closely at the photos in this guide before deciding to try this repair.
Был ли этот ответ полезен?
Счет 8
Добавьте свой ответ
Tom буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 1,874
