logic board grounding brackets?
will not haveing the grounding bracket installed prevent charging the phone? or any other issues?? basically what's it important for.
Это хороший вопрос?
Это хороший вопрос?
I just got one in that had that bracket missing. The phone would only boot half way thru with out it. It helps hold the connectors in tight. Once I replaced it the phone worked fine. See if this part in step 11 & 12 is what you are talking about: iPhone 5s Logic Board Replacement
Был ли этот ответ полезен?
You have to specify which one.
Some of those brackets are not just for grounding, they actually conduct RF signals. If those brackets are missing, you will lose reception.
Should be fine, If you have any doubt you could insulate with some electrical tape to make sure there is no short between the motherboard/housing/underside of screen.
i think you misunderstand me, there is a bracket between the motherboard and housing, connecting/grounding it, this part is missing on my phone and i want to know if thats why it won't charge? because the battery is fine and the flex cable is fine.
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 13
За всё время: 1,747
