This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
Why do my buttons get stuck?
When pressing the volume buttons they sometimes get stuck.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (4)
Выбранное решение
The buttons get stuck by either having dirt in the button or because something is stuck behind the button. If you are needing a guide to cleaning or replacing buttons on your ASUS MeMo pad refer to the following troubleshooting guide.
Asus MeMO Pad HD 7 Troubleshooting
Был ли этот ответ полезен?
Оценка 0
Dirty/greasy hands >> sticky buttons. Wash your hands, and/or use less hand cream on your finger tips and palms.
Оценка 0
sir good day. why my ASUS MeMO Pad HD 7(ME173) no camera pound , pls help
Оценка 0
Without much more detail, there's no way to efficiently determine why your camera is not "found" except systematically building back the tablet from a factory state
The most likely culprit is driver or app corruption and the software would need to be rebuilt whether the problem was software or hardware, so:
USE THE ASUS BACKUP APP TO BACK UP ALL APPS AND DATA TO A USB DRIVE OR CLOUD STORAGE. Manually copy all your photos, music and documents to Google Drive.
Do a factory reset of the tablet.
Test the camera.
If it works, the problem was a software defect. If it doesn't the camera hardware module is damaged.
If the tablet is now working, if it were me, I'd use the PlayStore Upgrade to get all the original apps up to the latest version, and then My Apps/All Apps.
All Apps lists with the most recently installed at the top.
Systematically reinstall the apps , working from the bottom of the list upward, skipping any that I don't use frequently for things I can't do without.
Оценка 0
Добавьте свой ответ
Julien Daigle будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 10
За последние 30 дней: 10
За всё время: 317
