Released November 2010. Identified by model number BNRV200.
Why is my battery draining quickly?
The battery in my device is draining until the point where it will not turn on. Is there a problem with my battery or the device itself?
Это хороший вопрос?
Счет 3
Добавить комментарий
3 Ответов
Try to charge your device. If it won't charge at all, the charger may be faulty. If a different charger won't charge the device, the problem is likely the battery. Otherwise, attempt to turn it on once it reaches full charge.
Have a look at the Nook Color troubleshooting page.
Был ли этот ответ полезен?
Счет 0
What can be done about charging the battery it won't hold a charge
Счет 0
I am having the same issue. The only different is, I have bought 2 replacement batteries and when they are on the charger, The dock and Nintendo’s stand alone chargers, they drain instead of charge.
Счет 0
Добавьте свой ответ
John Goly буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 1,059
